Thank god for Christmas and the belonging holidays. During this time I could go on with my Zoltar IGUS 2007 and it's pretty finished right now. First let's have a look and the result:
(http://dl.dropbox.com/u/59354966/IMG_1814.JPG)
One important goal was to have a "compact" CNC machine, where everything is put together on one trolley, so I took a MDF plate and mounted some rolls. The Linux-PC, stepper control and other electronic parts are just under the frame of the machine whereas on the top, there is the monitor, keyboard, mouse and some spare space on a rack.
In the following posts I'll present - as promised - technical data, some photos and description why and how I solved some parts of the machine different than proposed by Chris. Any comments are welcome! Have fun!
Here we go with some technical data:
- based on the Zoltar IGUS 2007 (-> http://members.home.nl/zoltar/CNC/igussystem/igus.html (http://members.home.nl/zoltar/CNC/igussystem/igus.html))
- Laser parts: 3mm stainless steel, some distance parts are 5mm alu
- Frame: 90x45mm aluminium bosch rexroth profiles
- Screws: Trapezium 12x3mm with nylatron nut
- Stepper motors: Nema23, 1,4Nm torque, unipolar driven
- Stepper control: PMinMO break out board for parallel port with Linistepper (http://www.piclist.com/techref/io/stepper/linistep/index.htm (http://www.piclist.com/techref/io/stepper/linistep/index.htm)), schematic, layout and PCB etching done by myself
- CNC software: EMC2 on Ubuntu 8.10
- Movement speed: ~600mm/min, half-step mode
- Spindle motor: Kress FME1050-1 (5000-25000 RPM)
Frame construction:
(http://dl.dropbox.com/u/59354966/IMG_1505.JPG)
X-Axis carriage:
(http://dl.dropbox.com/u/59354966/IMG_1507.JPG)
Claw clutch on every motor <-> thread connection:
(http://dl.dropbox.com/u/59354966/IMG_1508.JPG)
Ball bearings for the threads - here a simple M4 screw locks the bearings from shifting -> work perfect:
(http://dl.dropbox.com/u/59354966/IMG_1510.JPG)
I mounted the power stepper drivers (Linistepper) on a large heat sink, cooled by two 12cm fan. It is mounted together with two +12V switching power supplies (taken from old PCs) and a PMinMO break out board into an old ATX case.
(http://dl.dropbox.com/u/59354966/IMG_1681.JPG)
(http://dl.dropbox.com/u/59354966/IMG_1682.JPG)
(http://dl.dropbox.com/u/59354966/IMG_1772.JPG)
I drive the steppers in unipolar mode, this means, I routed a 5-pole cable with ground shielding from the drivers to the steppers. A simple DIN connector was perfect in number of pins. The end switches are connected via D_SUB9. There is an external connection for emergency stop button and the release switch. With 12V-Relais and an open collector circuit in the break out board I realized spindel on/off.
(http://dl.dropbox.com/u/59354966/IMG_1789.JPG)
My first attempts for profiling:
(http://dl.dropbox.com/u/59354966/IMG_1796.JPG)
(http://dl.dropbox.com/u/59354966/IMG_1781.JPG)
Hello There!
You have got that sorted well and placed it on a trolley.
Clever!
You've pretty much sticked to the plan as far as for the mechanics.
Only for what I see is a changed driveset.
That was open for personal changes of course.
A ballscrew upgrade is always an option for the future....
Anyhow, good job!
Glad you've come his far.
Now start cutting and building stuff!
Greetings,
Hey,
Great to see another IGUS machine!
I will put up pictures of mine soon.
I see we used the same option for the X frame.
Plan was to use a welded frame first from 50x50 steel.. but decided it was easier to use an aluminium frame just like you did!
Cheers
Peter
Hey Peter,
I already studied your thread on cnczone.nl before I went in for building my own machine. The idea of using alu frames was cribed by you and underlined by a friend of mine who supplied me with 45x90 alu frames for free! :)
greetz Johnsn
Hey ..
How's you IGUS machine doing? :P
Hope all is well..
