Author Topic: strengthen z-axis of the classic Zoltar  (Read 5687 times)
oscar
  • Full Member
« on: February 25, 2013, 10:56:02 AM »
By attaching  the Kress engine the way I did
the z-axis bends in one direction when used.
I found out with heavy using the round holes become slightly oval.
My plan is  to replace the vertical plate by a 12mm thick aluminum plate.
then use the same brackets for the kress motor.
OldRaven
  • Full Member
Re: strengthen z-axis of the classic Zoltar
« Reply #1 on: February 25, 2013, 04:27:37 PM »
Hey Oscar,
I have the same problem.
Also need to strengthen this for my kress.
Peter
oscar
  • Full Member
« Reply #2 on: February 25, 2013, 11:16:20 PM »
I am now cutting and sanding the 12mm alu block.
Without an CNC machine!
I will soon post the result here.
oscar
  • Full Member
« Reply #3 on: February 26, 2013, 04:39:59 PM »
Lets hope it brings the results I expect.
@ Chris : What do I use to glue the bearing to the lowest plate ( CA glue ? )
« Last Edit: February 26, 2013, 04:49:45 PM by oscar »
  • Hero Member
  • CNC-Addict!
    • Zoltar-CNC@HOME
« Reply #4 on: February 27, 2013, 08:56:33 PM »
Hello Oscar,
Seems you are having a lot of fun there.... :)
Upgrading the original 2001 first prototype after 13 years of service.
Thats great!
The bottom bearing does not need a seat / support and was self aligning.
Once the driveset is in position and running smooth,
you can add a drop of loctite thread locker to the edge of a bearing and
the bottom plate - if wished.
BTW, check the backlash on your delrin nuts - trapezium screws,
do minimize that with the setscrews and it will work as new.
Enjoy!
OldRaven
  • Full Member
« Reply #5 on: October 25, 2013, 10:10:59 PM »
Oscar,
Where did you get the aluminium holders for the fress that are mounted on the backplate?
I could really use those too...   yes yes..  I know. . I can mill them myself..  but I'm to lazy to do that :)
oscar
  • Full Member
« Reply #6 on: October 27, 2013, 08:20:57 AM »
Oscar,
Made them myself.
If you like I can search for the Cad file.
Oscar
OldRaven
  • Full Member
« Reply #7 on: October 27, 2013, 09:41:17 AM »
Hi oscar,
That would be great!
thanx
Peter
